Finding the diff ratio ? https://www.ausmini.com/forums/viewtopic.php?f=2&t=89197 |
Page 1 of 2 |
Author: | Morris 1100 [ Sat Apr 18, 2015 5:22 pm ] |
Post subject: | Re: Finding the diff ratio ? |
Try it again but with the car on the ground and push it in 4th gear. |
Author: | Phil 850 [ Sat Apr 18, 2015 5:28 pm ] |
Then it should only be 2 rotations of the wheel to allow for the half speed of the distributor right ![]() |
Author: | Phil 850 [ Sat Apr 18, 2015 5:41 pm ] |
Just wheeled along the driveway and two wheel rotations gave 4.05 at the distributor so allowing for parallax error both results are pretty close to each other. |
Author: | Morris 1100 [ Sat Apr 18, 2015 6:10 pm ] |
The nearest diff ratio to that would be a 4.1. Which is a fairly useless road diff in a Mini. |
Author: | Phil 850 [ Sat Apr 18, 2015 6:40 pm ] |
Morris 1100 wrote: The nearest diff ratio to that would be a 4.1. Which is a fairly useless road diff in a Mini. Useless is an understatement. I'm considering something around 3:1. It is an 1100S so it should pull that OK I think. |
Author: | Bubbacluby [ Sun Apr 19, 2015 12:35 am ] |
Mates runs a 3.1 in his cooper s and it still goes really well. |
Author: | Kennomini [ Sun Apr 19, 2015 9:36 am ] |
I can't comment on how to find your current diff ratio but I do have a 3:1 in my car and I love it. It still has good acceleration and is great on the highway. |
Author: | MiniVLT [ Sun Apr 19, 2015 10:50 am ] |
4th gear is 1:1 so whatever your diff ratio is will be 2 x the dizzy rotation since the dizzy rotates at half the engine speed! With the car in 4th gear and the road wheel turned 1 revolution, the dizzy should have turned 2.05 times for you 4.1:1 diff ratio yeah? Cheers Shane |
Author: | Phil 850 [ Sun Apr 19, 2015 5:10 pm ] |
Thanks Bubbacluby, Kennomini & MiniVLT for the info on diff ratios. I'll have to chase up a 2.95:1 or a 3.1:1. Phil |
Author: | 9YaTaH [ Mon Apr 20, 2015 12:29 pm ] |
Interesting outcome ...hope you pulled the plugs before pushing in 4th ![]() |
Author: | Morris 1100 [ Mon Apr 20, 2015 12:38 pm ] |
9YaTaH wrote: Interesting outcome ...hope you pulled the plugs before pushing in 4th ![]() Why? It will push quite easily in 4th. |
Author: | 9YaTaH [ Mon Apr 20, 2015 5:53 pm ] |
Morris 1100 wrote: 9YaTaH wrote: Interesting outcome ...hope you pulled the plugs before pushing in 4th ![]() Why? It will push quite easily in 4th. Oh sorry Mike, didn't allow for your clapped-out, needs new rings, lots of blow-by, low compression engine ![]() ![]() |
Author: | Phil 850 [ Mon Apr 20, 2015 6:03 pm ] |
Yes, pulled the plugs otherwise I might've needed a new ring ![]() |
Author: | Mick [ Mon Apr 20, 2015 7:47 pm ] |
