Castor angle for LSD https://www.ausmini.com/forums/viewtopic.php?f=2&t=89199 |
Author: | gtogreen1969 [ Sat Apr 18, 2015 7:01 pm ] |
Post subject: | Castor angle for LSD |
I will be setting up my steering soon. Does anyone know if the castor angle should be changed when running a LSD. I was going to start off with 5deg and see how it goes. |
Author: | Kennomini [ Sun Apr 19, 2015 9:38 am ] |
Post subject: | Re: Castor angle for LSD |
Out of curiousity dose the type of LSD matter in this topic? |
Author: | gtogreen1969 [ Sun Apr 19, 2015 7:12 pm ] |
Kennomini wrote: Out of curiousity dose the type of LSD matter in this topic? Not sure. A heavier preload LSD is heavier to steer. But i dont know if you need to change the castor angle to counteract any steering heaviness. I don't have much info on my diff. I found a scrap of paper in the pile of receipts that came with the car. It has "LSD 80psi" scribbled down on it. So i am assuming it is an 80psi preload Salisbury LSD. |
Author: | HistoricRacingS [ Sun Apr 19, 2015 9:25 pm ] |
It will be light as long as you don't back off the throttle ![]() |
