It is currently Mon Jul 21, 2025 11:24 am
PostPosted: Wed Apr 22, 2015 10:46 am
Hi,
Do i need to do anything special to bleed a new brake system (new master cyilinder, lines, slaves) currently has no fluid at all.
thanks
PostPosted: Wed Apr 22, 2015 11:50 am
I use a Gunson Eezibleed and for a Mini they recommend bleeding the m/c seperately first. i.e. with the rest of the system disconnected.
I have a bit of plastic tubing jammed into the end off a flexible brake hose that I use. It fits the thread in the top of the master cylinder and lets you direct the fluid into a jar.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Apr 22, 2015 2:27 pm
I went through this recently. Bench bleed MC's first before attaching to lines. I then gravity bled the system by cracking open the bleeder furthest away from MC working my way towards them, although I have read people opening them all at once.
I have a brake booster under the right wheel arch which I bled first.
How is your pedal assembly? If I had to do it again, I would clean that up before reassembling the MC's to the firewall...
PostPosted: Wed Apr 22, 2015 3:14 pm
What is the benefit of bleeding the M/C first?
Ive never done and had no dramas bleeding up a bone dry system.
PostPosted: Wed Apr 22, 2015 4:07 pm
It was my first attempt to bleed brakes ever and I simply went on what I read and was advised. Perhaps for gravity bleeding, having some fluid in the cylinders first helps things get going.
