bleeding new brake system https://www.ausmini.com/forums/viewtopic.php?f=2&t=89221 |
Author: | nicholasatkins [ Wed Apr 22, 2015 10:46 am ] |
Post subject: | bleeding new brake system |
Hi, Do i need to do anything special to bleed a new brake system (new master cyilinder, lines, slaves) currently has no fluid at all. thanks |
Author: | Timbo [ Wed Apr 22, 2015 11:50 am ] |
Post subject: | Re: bleeding new brake system |
I use a Gunson Eezibleed and for a Mini they recommend bleeding the m/c seperately first. i.e. with the rest of the system disconnected. I have a bit of plastic tubing jammed into the end off a flexible brake hose that I use. It fits the thread in the top of the master cylinder and lets you direct the fluid into a jar. Tim |
Author: | Fishyoil [ Wed Apr 22, 2015 2:27 pm ] |
I went through this recently. Bench bleed MC's first before attaching to lines. I then gravity bled the system by cracking open the bleeder furthest away from MC working my way towards them, although I have read people opening them all at once. I have a brake booster under the right wheel arch which I bled first. How is your pedal assembly? If I had to do it again, I would clean that up before reassembling the MC's to the firewall... |
Author: | Hanra [ Wed Apr 22, 2015 3:14 pm ] |
What is the benefit of bleeding the M/C first? Ive never done and had no dramas bleeding up a bone dry system. |
Author: | Fishyoil [ Wed Apr 22, 2015 4:07 pm ] |
It was my first attempt to bleed brakes ever and I simply went on what I read and was advised. Perhaps for gravity bleeding, having some fluid in the cylinders first helps things get going. |
