How to remove external door hinges
https://www.ausmini.com/forums/viewtopic.php?f=2&t=89275
Author:  shnitzee [ Mon Apr 27, 2015 12:28 am ]
Post subject:  How to remove external door hinges
Hi all
I'm having a bit of trouble removing the door hinges from the newly acquired 76 rust bucket, specifically the segment that attaches to the body.
Advice is greatly appreciated.
Eiles
Author:  boomini [ Mon Apr 27, 2015 1:57 am ]
Post subject:  Re: How to remove external door hinges
7/16 socket, swivels, extensions, spanners..
Its a crap of a job eiles. ..
There is two bolts/nut under the wheel arch per hinge. Bottom ones are easy.. top ones are hard.
Author:  ba_dm_tsh [ Mon Apr 27, 2015 2:34 am ]
If you're just looking to get the doors off you can always centre punch and drill out the hinge pins too.
Author:  drmini in aust [ Mon Apr 27, 2015 8:31 am ]
I use an old 7/16 dwarf ring/OE spanner, with the ring end thinned down and a bend put in the shank.
Author:  Mick [ Mon Apr 27, 2015 10:45 am ]
A 1/4" Sidchrome Socket set is the greatest toolset you can own when you are doing work on Minis. This is certainly one of those jobs.
Author:  Timbo [ Mon Apr 27, 2015 12:01 pm ]
If you're really lucky, once you dig all the dirt out from behind and finally get some purchase on the nut, the little 1/4" studs will just shear, and the hinges will literally fall off.
Author:  winabbey [ Mon Apr 27, 2015 12:31 pm ]
... or the stud will unscrew from the bracket rather than the nut undoing. Regardless it can be repaired via various methods.
Author:  shnitzee [ Mon Apr 27, 2015 12:51 pm ]
Thanks for the all detailed replies. :D
Ill have a go this arvo.
I'm trying to pull off all the bits worth saving as replacement/spares for the 77 mini.
I definitely need better tools.
Eiles
Author:  69k1100 [ Mon Apr 27, 2015 2:10 pm ]
If youre scrapping the shell why not cut the A-panel off, then they're easy to remove.
Author:  jpodge [ Mon Apr 27, 2015 7:32 pm ]
I remember when I took my door hinges off my 76 clubby. I wish i had known it wasn't an actual bolt but a nut and a stud. 6 hours of swearing later, I figured it out why the socket wasn't seating on the nut...
