It is currently Thu Jul 24, 2025 1:22 am
 Post subject: Rod change cotton reels
PostPosted: Wed Apr 29, 2015 7:17 pm
I was thinking of making some of these out of nylon / plastic, do you think they would be too rigid
http://www.moke.com.au/images/stories/M ... _Reels.jpg
PostPosted: Wed Apr 29, 2015 7:22 pm
Yep: they'll last about 3 minutes - they're rubber for a reason.
If you want to tighten up the gearstick motion a bit, just put another rubber one in.
I have three on mine - solid as a rock but still copes with the engine movement / vibrations.
PostPosted: Wed Apr 29, 2015 7:38 pm
Thanks. Thought as much they would be easy to make hence the question.
I will order some new ones as my original are soft, possibly never been changed and they got a tad hot in the fire.
PostPosted: Wed Apr 29, 2015 9:41 pm
The previous owner of my car did this top notch mod. Image
PostPosted: Thu Apr 30, 2015 8:42 am
You can try exhaust mount ones, they're a bit stronger but still rubber. Don't forget the bushes in housings. Oh, and some mudguard washers might fix your problem.
