It is currently Tue Jul 29, 2025 11:55 pm
PostPosted: Sat May 02, 2015 1:12 pm
Hi all
I was just wondering what the difference between mini K and the MK2 S close ratio gears were?
I'm not too sure what is in the box at the moment, but coming up for its rebuild I'd like to know whether the difference between the two would be noticeable? It's a K box but had things changed inside over time apparantly so could really be anything in there.
Option 2: if whatever gears inside are completely stuffed, what are people using now as a replacement?
James
PostPosted: Sat May 02, 2015 1:21 pm
Standard laygear has 22g927 on it. Cooper S has 22g1040
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat May 02, 2015 1:24 pm
Mini K's 1st motion shaft is 17T, Cooper S is 18T.
So, on an S, 1st 2nd & 3rd are 1/17th taller geared, 4th is the same.
Note the Cooper S 22G1040 cluster gear has the same tooth count as the Mini K, however the diameter of the big gear is ~.050" smaller diameter to mesh with the 18T gear of the 1st motion shaft.
PostPosted: Sat May 02, 2015 1:30 pm
The overall gear ratios for both are in the specification table in this brochure - viewtopic.php?f=32&t=73886
PostPosted: Sat May 02, 2015 2:15 pm
So, I wouldn't be able to buy an 18T first motion shaft to 'convert it' to almost S ratio gearing because of the big gear being that bit smaller, right?
PostPosted: Sat May 02, 2015 2:28 pm
That is correct, you need to buy both the 1st motion shaft and the cluster gear.
Note there are two 18T 1st motion shafts, the S one 22G1371 (for 14mm nose mainshaft) and the later GT? one DAM3167 (for 18mm nose mainshaft).
If you can't buy the former, the latter one works- but you either need a 18mm mainshaft, or PM me about converting your 14mm shaft to 18mm type. Can do this with 2nd & 3rd gears left on it.
[edit] p/nos added.
Last edited by drmini in aust on Sat May 02, 2015 3:34 pm, edited 1 time in total.
PostPosted: Sat May 02, 2015 2:36 pm
Note there are two 18T 1st motion shafts, the S one (for 14mm nose mainshaft) and the later GT? one (for 18mm nose mainshaft).
Thanks doc, I think I might just get you to sort it out when the time comes!
James
Users browsing this forum: No registered users and 47 guests
