RH Fuel tank
https://www.ausmini.com/forums/viewtopic.php?f=2&t=89314
Page 1 of 2
Author:  Dutchy1978 [ Fri May 01, 2015 11:31 am ]
Post subject:  RH Fuel tank
Considering I am doing a Vtec conversion I thought it would be a good idea to add a RH fuel tank. My now supercharged mini chews through the petrol and in-turn see me in the fuel station way too often.
How do people find the fuel economy of the Honda Vtec?
Does anyone have a RH fuel tank they would like to off load?
I am in Melbourne so easier if local but open to any offers.
Author:  Irish Yobbo [ Fri May 01, 2015 12:01 pm ]
Post subject:  Re: RH Fuel tank
I'm interested in this too - I'm starting on an engine conversion, and while I don't expect to be using more fuel, a longer range is always nice.
I'm also still not sure why there needs to be a 2nd filler cap - can somebody please educate me? Surely fuel can run from one tank to another?
Regarding fuel economy of a vtec, a b-series civic is supposed to get around 7.5l/100km. You will use a little less because it's a lighter car, but then you will also probably use more because of the gear ratios, so that's probably about right.
Author:  peterb [ Fri May 01, 2015 12:30 pm ]
How would you do the fuel pump fitment, just in one tank and other draining into it? twin pumps? Single pump and 2 bigger outlets? Just curious.
How about extending the single tank.
Author:  Aussie Brian [ Fri May 01, 2015 12:32 pm ]
Purely for filling otherwise you would grow a beard waiting for the fuel to equalise through the interconnecting tube
Author:  Irish Yobbo [ Fri May 01, 2015 12:36 pm ]
I would have thought the would use a large tube at the bottom (for fuel to run from the left to the right) and a small tube at the top (to allow air to flow from the right to the left). It seems strange they would use a small single line and an extra filler cap.
Author:  winabbey [ Fri May 01, 2015 1:16 pm ]
Irish Yobbo wrote:
I would have thought they would use a large tube at the bottom (for fuel to run from the left to the right) and a small tube at the top (to allow air to flow from the right to the left). It seems strange they would use a small single line and an extra filler cap.
That would mean manufacturing a new component with (unnecessary) extra cost. You'd have a normal LH tank with usual small hose outlet to engine, and new LH tank with large pipe to RH tank. It was much simpler engineering wise and cheaper to just do what they did and utilise the standard LH tank across the whole range of Mini sedans, whether they had a RH tank or not. Of course changes were eventually needed to the LH tank when emission control measures became important.
Author:  peterb [ Fri May 01, 2015 1:26 pm ]
wouldn't it be best to use rover tank with pump or modify an LS1275 tank to say 1/2" outlet fitted in sender unit.
Author:  Irish Yobbo [ Fri May 01, 2015 1:27 pm ]
That makes sense - at least BMC sense. Do all LH tanks have a bung to the RH tank? Or is the pipe connecting the two tanks 'forked' to connect both, before heading towards the engine?
Author:  winabbey [ Fri May 01, 2015 1:31 pm ]
Yes, forked. The two tanks connect via normal fuel line with a T-piece that heads to the engine.
Author:  Irish Yobbo [ Fri May 01, 2015 1:42 pm ]
That clears that up then :)
I remember a while ago there was somebody selling plastic RH fuel tanks for a mini on ebay. They were brand new, and about $350 I think. They don't seem to be there anymore, and most others I can find are quite expensive. Maybe that's why everybody doing a conversion seem to go for a fuel cell?
Author:  winabbey [ Fri May 01, 2015 1:55 pm ]
Paul Gulson developed the plastic RH tank and sold them on eBay but I seem to remember he doesn't sell them now. Was it Matt Read who took it over? Suggest you give him a call.
Author:  Dutchy1978 [ Fri May 01, 2015 10:11 pm ]
If I go ahead I would have a second tank on the right side with filler for faster filling and an equalising hose down the bottom.
Fuel pump would remain in the LH tank as per normal. I have a rover tank with SPI pump so would keep this if the pump was strong enough.
The idea of having a larger equalising hose and no filler sounds good too as it would mean no extra holes in the body?
I don't think I want a plastic tank though. I would want a matching RH in metal one.
Author:  BBY755 [ Fri May 01, 2015 10:38 pm ]
Here be one in metal.....
On special too.......
http://minisport.com.au/mini-rah-steel- ... -brand-new
Author:  Bennjamin [ Sat May 02, 2015 10:35 am ]
just some thought
I too have a vtec conversion. Dual tank. SPI LHS tank with a walbro in tank fuel pump.
This runs as per original SPI setup...line to regulator then return on standard Carby return line. The RHS tank runs a lower bung to the other side - and that's it. Both are vented tanks , so will gradually even out over time.
Author:  Harley [ Sat May 02, 2015 1:12 pm ]
Spi pump wont be upto the job for a vtec- it only has to feed 1 injector, not 4.
I did the walbro pump in the stock tank too.
The other thing to consider is not running a mini tank at all and fitting say a 50 litre alloy tank in thr boot?
