It is currently Fri Jul 18, 2025 3:59 pm
 Post subject: PM problems
PostPosted: Wed May 06, 2015 7:37 pm
When I send a PM it shows as sent but it remains in my Outbox.
It should go to my Sent folder but it doesn't.
How do I contact the Administrators as I cant PM them either. :(
 Post subject: Re: PM problems
PostPosted: Wed May 06, 2015 7:40 pm
I thought they stayed in the outbox till the recipient reads them then they move from your outbox to your sent box. I could be wrong as I have been known to be miss-informed a lot.
PostPosted: Wed May 06, 2015 7:52 pm
^^^ this is correct.
PostPosted: Wed May 06, 2015 7:54 pm
Well that explains it then. :D
I expected it to be like Email.
Thanks
Phil
PostPosted: Wed May 06, 2015 8:48 pm
At least you know the addressee has read it. :wink:
PostPosted: Wed May 06, 2015 9:00 pm
And if you make a mistake you can edit it before they see it if it's still in the outbox
PostPosted: Wed May 06, 2015 9:23 pm
I see this has already been dealt with...so I'll move right along...
PostPosted: Wed May 06, 2015 9:58 pm
Hi Mick
I sent you a PM but got an answer from the "brains trust" on here as above before you had the time to answer, so I deleted it.
Thanks all
Phil
PostPosted: Wed May 06, 2015 10:04 pm
Yeah and thats the first time I ever have noticed that when you send me a PM, and delete it before I read it, the PM is still there, but recorded as Deleted by the Sender. It has your name in the column next to it as well.
I never saw that before tonight.
Users browsing this forum: Bing [Bot] and 83 guests
