What Mini is this from? https://www.ausmini.com/forums/viewtopic.php?f=2&t=89342 |
Author: | bluewhitecoopers1968 [ Sun May 03, 2015 10:16 am ] |
Post subject: | What Mini is this from? |
Can anyone enlighten me as to what model Mini this steering wheel is off, also could it be fitted straight onto a mk2 column? Cheers. Richard. ![]() |
Author: | peterb [ Sun May 03, 2015 10:31 am ] |
Post subject: | Re: What Mini is this from? |
Are you sure it's a Mini one, looks like steering wheel on my brothers boat. has it got any writing on back? |
Author: | Mick [ Sun May 03, 2015 10:41 am ] |
Certainly not an Australian factory one. |
Author: | 9YaTaH [ Sun May 03, 2015 11:02 am ] |
Mick wrote: Certainly not an Australian factory one. Does that include boat factory's ![]() ![]() |
Author: | Morris 1100 [ Sun May 03, 2015 11:07 am ] |
Triumph TR7. |
Author: | 9YaTaH [ Sun May 03, 2015 11:08 am ] |
Morris 1100 wrote: Triumph TR7. Yep...boat anchor ![]() |
Author: | Morris 1100 [ Sun May 03, 2015 11:08 am ] |
http://www.ebay.co.uk/itm/Triumph-TR7-T ... 1459373927 |
Author: | peterb [ Sun May 03, 2015 11:44 am ] |
9YaTaH wrote: Morris 1100 wrote: Triumph TR7. Yep...boat anchor ![]() see, I was close. ![]() |
Author: | Timbo [ Mon May 04, 2015 4:34 pm ] |
A bit of googling suggests that the TR7 used the same 3/4" x 48 spline hub as the Mini steering wheel, so it should fit straight on. It may not end up in the same relative position as the original wheel, and it may not have the same taper as the Mini steering column so it might tear the splines out and just free-wheel on the shaft at a later date, but it should go on OK. Tim |
