It is currently Mon Jul 21, 2025 4:23 am
PostPosted: Mon May 04, 2015 11:45 pm
What can I clean up a tacho with that won't stuff up the workings?
Sometimes my needle doesn't want to return to 0.
Tapping on it fixes it but I want to fix the problem before it breaks.
Edit, Weapons of choice are (CO Contact cleaner, Lectra clean, Silicone spray, WD40)
PostPosted: Tue May 05, 2015 7:47 am
Have you looked inside yet? Might be something really obvious like a bit of dirt or sticky crud.
Be aware but, you might find the little hamster that spins it round might be sick, have a broken leg or worst of all his walking frame might be jambing something. :-)
PostPosted: Tue May 05, 2015 10:06 am
Haven't pulled it apart. Just seeing what people have used in the past to clean and lubricate it with.
PostPosted: Tue May 05, 2015 11:56 am
DO NOT spray anything in there unless you know what you are doing :idea:
Keep it away from workbenches if you open it (recommend newspaper on Laundry Bench or Kitchen table)
