Cam Follower Destruction https://www.ausmini.com/forums/viewtopic.php?f=2&t=89362 |
Page 1 of 2 |
Author: | GR [ Tue May 05, 2015 2:07 pm ] |
Post subject: | Cam Follower Destruction |
Hi All, I don't have to say much. Please grind your Cam Followers..... He thought he was putting the best of everything in it, this is the result after a few thousand kilometres. ![]() These cam followers weren't Kent followers, they were a lightened follower that most people use in their motors. Graham Russell ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | MiniBob [ Tue May 05, 2015 2:25 pm ] |
Post subject: | Re: Cam Follower Destruction |
Nasty, bet that was rattling a bit. |
Author: | Mick [ Tue May 05, 2015 4:31 pm ] |
That is horrific! |
Author: | winabbey [ Tue May 05, 2015 4:32 pm ] |
Nothing five minutes with some emery paper wouldn't fix. ![]() Anyway, Graham, it's not all bad news. At least it wasn't one of your cams that was destroyed. ![]() |
Author: | Beanie [ Tue May 05, 2015 5:03 pm ] |
bugga ![]() |
Author: | Morris 1100 [ Tue May 05, 2015 6:24 pm ] |
Needs more zinc in the oil. |
Author: | drmini in aust [ Tue May 05, 2015 7:01 pm ] |
IMO it's a good idea to check your valve lift figures from time to time with a dial gauge. If the lift starts going south, and you are getting mucho stuff on the sump plug magnet, you may have a problem.... [edit] I wore a Camtech VP3 cam down once, valve lift (1.5 rockers) dropped from .490" to .270"...! |
Author: | Scoop [ Tue May 05, 2015 8:16 pm ] |
Yikes. Mick summed it up pretty well (Horrific). |
Author: | VulcanBB18 [ Tue May 05, 2015 9:08 pm ] |
That's pretty much my worst nightmare in pictures... ![]() cheers, Jacob |
Author: | FNQ [ Wed May 06, 2015 8:49 am ] |
An additional question sort of in the same ballpark.... I see mentioned that a hardness of 55-57 Rockwell Hardness is recommended for lifters. Does a reground cam need to be heat treated to match this or slightly exceed this figure- but whilst asking this, i doubt hardness played any key factor in this scenario.. ouch |
Author: | bent65 [ Wed May 06, 2015 9:15 am ] |
What do you think post mortem is Graham? No radius on followers and no rotation, or hardness issues as well? Were the spring pressures OTT? cheers Ben |
Author: | Besser [ Wed May 06, 2015 10:48 am ] |
As Harvey Keitel said "someone has to pay" |
Author: | Mick [ Wed May 06, 2015 11:02 am ] |
The surface looks like it shatters like glass... |
Author: | drmini in aust [ Wed May 06, 2015 1:13 pm ] |
Mick wrote: The surface looks like it shatters like glass... Surface is white iron, hard as. (lifters are cast iron, chill cast on the end). |
Author: | GR [ Wed May 06, 2015 7:19 pm ] |
Hi Ben Just grind you followers can save a lot of tears. Graham Russell |
