Strange spark plug phenomenon
https://www.ausmini.com/forums/viewtopic.php?f=2&t=89401
Author:  willy [ Sat May 09, 2015 7:45 pm ]
Post subject:  Strange spark plug phenomenon
Hey all
Just starting to sort out the tune properly on my 850.
I fitted a new Powerspark distributor (25D) with electronic module, and changed it to a negative earth system while I was at it.
New plugs, new leads, new coil.
Everything sweet.
What is not sweet, however, are the spar plugs.
Cyl 1 and 2 are very rich. A very sooty plug.
Cyl 3 and 4 are pretty spot on - absolutely clean.
It has 19° advance at 1000 rpm - as per a workshop manual which seemed to me extremely advanced for an 850.
.... What do we think?
Any help appreciated.
Author:  Harley [ Sat May 09, 2015 10:43 pm ]
Post subject:  Re: Strange spark plug phenomenon
1 and 2 down on compression compared to 3 and 4?
Author:  peterb [ Sun May 10, 2015 8:11 am ]
Have you got twin carbs?
Author:  willy [ Sun May 10, 2015 9:24 am ]
I'm yet to do a compression test.
And only a single HS2 on this wheezy girl.
I sprayed WD40 around the inlet manifold to head area and there was no difference in noise, so I don't think there is a manifold sealing issue but I can't be certain until I pull it off and change it.
Author:  aaron [ Sun May 10, 2015 10:51 am ]
Rather than wd40, use carb cleaner.
I would also check your gaps on the plugs along with swapping them over in the cylinders. I found a few plugs recently aren't quite doing what they are supposed to.
Author:  willy [ Sun May 10, 2015 1:00 pm ]
35 thou on each plug, which is about right for an elec dizzy I would have thought.
I'll try testing new plugs to see if there is a plug fault.
Author:  drmini in aust [ Sun May 10, 2015 2:39 pm ]
If you get any misfiring during warmup, reduce plug gap to .030".
Author:  willy [ Sun May 10, 2015 5:54 pm ]
Cheers Doc I'll keep that in mind.
Do you think 19 degrees (at 1000rpm) on a strobe is far too advanced?
Author:  drmini in aust [ Sun May 10, 2015 7:33 pm ]
Probably is, for a stock motor.
My 1360 (has bathtubbed race head) was running 20deg static when I had the Pulsar dizzy in. Since fitting the Accuspark black box I've dropped that back a bit, but it still has 20deg @1000rpm.
Author:  Irish Yobbo [ Sun May 10, 2015 10:19 pm ]
Also be sure to check your rocker clearance.
But I'd do a compression test as a first port of call.
Author:  drmini in aust [ Sun May 10, 2015 10:23 pm ]
Check your plug lead resistance. Old cheapo carbonized string ones increase resistance with age, eventually this reduces spark energy and plugs foul easily.
I like Bosch (or similar) inductive core leads. They don't do this.
Author:  simon k [ Sun May 10, 2015 10:37 pm ]
new dizzy, new plugs, new leads, new coil
what state was it in before you started working on it?
were the old plugs in the same condition (2 good, 2 bad) when you took them out?
have you checked the compression on all 4 yet?
have you swapped the plugs and leads around yet?
I've noticed that 850's are set up with a lot of advance as per the book - I assumed it was because they don't breathe very well with their little valves and a tiny bore, and then with the low compression don't get a very fast burn, so running a lot of advance gives it plenty of time to ignite and burn all of the fuel before the piston gets to the top... or something
