Morris Mini K 1971 Dash https://www.ausmini.com/forums/viewtopic.php?f=2&t=89412 |
Author: | ewatkins [ Mon May 11, 2015 11:37 am ] |
Post subject: | Morris Mini K 1971 Dash |
Hi Guys, Just a few quick questions... first mini I am restoring at the moment, have pulled off the dash and found that someone in its history has cut the dash switch panel to fit something stupid or another (see photo), and I want to replace it to original... Questions, are the 1971 Mini K's running the early MK1 dash switch panel with the smaller opening or the wider cooper switch holes? (see images) trying to find out & replace the cut panel. Have linked photos below. I would have said it looked more like the thinner one... Thanks in advance! Evan |
Author: | frednutz&co [ Mon May 11, 2015 1:06 pm ] |
Post subject: | Re: Morris Mini K 1971 Dash |
have the remains of a 78 van the dash is still in a lot better condition than yours .you can have it just need to come and get it from Ferntree gully. you will have to cut it out ![]() |
Author: | 850man [ Mon May 11, 2015 1:08 pm ] |
All Mini Ks had the Mk 1 switch panel. The 2nd photo you have of the Cooper is a English Mk2, that switch panel was not available in Australia. |
Author: | ewatkins [ Mon May 11, 2015 1:48 pm ] |
Thanks guys, having a look at another one on Wednesday fred, if i cant get that one out will be in touch! Cheers, Evan |
Author: | frednutz&co [ Mon May 11, 2015 1:59 pm ] |
OK no problems its not going anywhere ![]() |
Author: | 850man [ Mon May 11, 2015 2:59 pm ] |
78 van dash lower panel is different, it wont work in a Mini K if you are looking at returning it back to original. |
