Output seals https://www.ausmini.com/forums/viewtopic.php?f=2&t=89420 |
Author: | bluewhitecoopers1968 [ Tue May 12, 2015 9:20 am ] |
Post subject: | Output seals |
Any tips on how to get these out without damaging the covers. I've tried levering them with a screwdriver but there stuck fast. Cheers. ![]() |
Author: | drmini in aust [ Tue May 12, 2015 9:59 am ] |
Post subject: | Re: Output seals |
Grab flange in the vice, Use big flat screwdriver to lever it out. |
Author: | Tim I [ Tue May 12, 2015 10:27 am ] |
Yep, what the doc said. Or maybe you could also attack them from the back as well. I changed mine while still bolted to the case, so they just levered out. |
Author: | bluewhitecoopers1968 [ Tue May 12, 2015 1:29 pm ] |
Got the buggers out. Ended up using a small jemmy bar. They were glued in I think. |
Author: | drmini in aust [ Tue May 12, 2015 1:53 pm ] |
No need to glue them with anything. They are rubber coated; fit them dry and they seal, and don't slide about. |
Author: | bluewhitecoopers1968 [ Tue May 12, 2015 2:00 pm ] |
drmini in aust wrote: No need to glue them with anything. They are rubber coated; fit them dry and they seal, and don't slide about. Will do, thanks Kevin. |
