It is currently Sat Aug 16, 2025 11:07 am
PostPosted: Thu May 14, 2015 10:20 pm
Hey all,
Have a 78 Clubman (Baby poop yellow !) with front qtr damage.
Looking for recommendations for panel repair shop to help out in the Sth East burbs of Melb.
Don't want to go just anywhere. Would predfer someone who knows their Minis ! ('cos I dont) :?:
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Thu May 14, 2015 11:47 pm
Rohde Smash Repairs Ferntree Gully 97582081 proper repair place looks after all our minis old jags lots of classics
65 panel van Sprog
73 panel van Iggy
PostPosted: Fri May 15, 2015 8:26 am
That isn't 'baby poop' yellow. Thats nugget gold.
They are 12" factory wheels (probably hiding 8.4" discs) and those wheel nuts (that used to have a plastic wheel cover) confirm its a 1275 LS.
Justin
PostPosted: Fri May 15, 2015 9:03 am
1275LS. Definitely worth saving!
PostPosted: Fri May 15, 2015 11:26 am
Thanks Guys. Yep 1275LS. Nugget Gold it is then !
I'll have a chat to Rhode.
PostPosted: Wed Jun 10, 2015 7:56 pm
OK,
So we've had the word, and it aint pretty.
Both wings bent and we need outer and inner panels for both wings plus some front pieces.
Have put the word out in the WTB section.
Being newbies not to sure where to go looking for parts.
Any ideas whereabouts we could source front cut or shells in Melb area ?
PostPosted: Wed Jun 10, 2015 8:38 pm
As a starter if you want new panels many of the Mini businesses have them. Some have online stores where you can check prices.
See here - viewtopic.php?f=41&t=83593
PostPosted: Wed Jun 10, 2015 9:18 pm
Thanks Winabbey.
Am onto the online stores and will be working our way through the contacts there.
Not sure yet we can source new inner panels. Anyway, thanks.
PostPosted: Sat Jun 13, 2015 9:13 pm
Check with Brian at Link Automotive in Mitcham.
He has some NOS. Not sure what he has for Clubman panels but you may get lucky. Otherwise he always has shells he is cutting up.
I'd also suggest having a chat to Adrian Read. Some of the things he does with crashed Minis is amazing! He has been learning about Minis since in nappies as his Dad is Len Read.
http://www.arsmashrepairs.com.au/
HRS
PostPosted: Sun Jun 14, 2015 4:19 pm
Thanks HRS. Will check that out
PostPosted: Tue Jun 16, 2015 1:45 pm
Pretty sure you an still get new panels from British Motor Heritage.
If unable to source from Australia then could try UK
Also try Karcraft in Sydney or Mini King online
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jun 16, 2015 7:05 pm
Thanks Michaelb. Just found your 1275LS build. Havent read through yet, gather from your sig that it's no longer stock :shock:
PostPosted: Tue Jun 16, 2015 7:11 pm
You are correct. It's been pimped to the max and should help make all the other 1275LS's more valuable.. :wink:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Jun 16, 2015 7:19 pm
We can only hope ! :mrgreen:
