It is currently Tue Jul 22, 2025 9:37 am
 Post subject: Brake Booster?
PostPosted: Mon May 25, 2015 9:58 pm
Hey Guys,
I'm looking at putting a brake servo into my morris mini... its running front discs and rear drums, 1340cc engine. Which is a good servo to use? been having a look online and seeing a bit of pbr vh44... but that says its only really suitable for drum/drum config...
What do you guys run and whats the best brand/model to buy for a brake servo?
Cheers!
 Post subject: Re: Break Booster?
PostPosted: Mon May 25, 2015 10:05 pm
VH44 would be the most widely used booster on early minis. Good on Disc/Drum.
PostPosted: Mon May 25, 2015 10:28 pm
I think you could also say the VH44 was the most commonly used server in the 60s and 70s?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon May 25, 2015 10:29 pm
There were various VH44 servos. Even some Valiants ran em. Cooper S Mk2 had a VH44J.
PostPosted: Tue May 26, 2015 6:58 am
ok will look into them.
thanks guys.
PostPosted: Tue May 26, 2015 11:18 am
You can buy new replicas of the ones originally fitted to the Mk I S....
Saves messing with something thst may not have the correct specs for your application. By the time you find overhaul kits/have the work done, a new one may be cost competitive.
Try Minisport Adelaide's web site.
Cheers, Ian
 Post subject: Re: Brake Booster?
PostPosted: Tue May 26, 2015 7:31 pm
Not to confused with VH40 which is for drum brakes.
