Brake Booster? https://www.ausmini.com/forums/viewtopic.php?f=2&t=89530 |
Author: | ewatkins [ Mon May 25, 2015 9:58 pm ] |
Post subject: | Brake Booster? |
Hey Guys, I'm looking at putting a brake servo into my morris mini... its running front discs and rear drums, 1340cc engine. Which is a good servo to use? been having a look online and seeing a bit of pbr vh44... but that says its only really suitable for drum/drum config... What do you guys run and whats the best brand/model to buy for a brake servo? Cheers! |
Author: | gtogreen1969 [ Mon May 25, 2015 10:05 pm ] |
Post subject: | Re: Break Booster? |
VH44 would be the most widely used booster on early minis. Good on Disc/Drum. |
Author: | michaelb [ Mon May 25, 2015 10:28 pm ] |
I think you could also say the VH44 was the most commonly used server in the 60s and 70s? |
Author: | drmini in aust [ Mon May 25, 2015 10:29 pm ] |
There were various VH44 servos. Even some Valiants ran em. Cooper S Mk2 had a VH44J. |
Author: | ewatkins [ Tue May 26, 2015 6:58 am ] |
ok will look into them. thanks guys. |
Author: | 1071 S [ Tue May 26, 2015 11:18 am ] |
You can buy new replicas of the ones originally fitted to the Mk I S.... Saves messing with something thst may not have the correct specs for your application. By the time you find overhaul kits/have the work done, a new one may be cost competitive. Try Minisport Adelaide's web site. Cheers, Ian |
Author: | Stibbsy [ Tue May 26, 2015 7:31 pm ] |
Post subject: | Re: Brake Booster? |
Not to confused with VH40 which is for drum brakes. |
