Slave cylinder could be sucking air around the seal.
Original slave cylinders had a shaped plastic bit behind the seal to maintain its shape. The silver aftermarket ones don't.
So if replacing seals in the latter, pinch the plastic bit out of an original cylinder and fit that in there.
The seal is a plain 7/8" cup seal, available from almost any brake shop.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
