It is currently Mon Jun 30, 2025 12:44 pm
 Post subject: quick question
PostPosted: Thu Apr 20, 2006 10:27 pm
do 10" contessas fit without needing flares on standard drums? The ones with a deeperdish ones, not with the centre flush with the outside.
PostPosted: Fri Apr 21, 2006 8:56 am
Not quite. I've got them on my new white roundy which has flat faced drums on the front and 1/2" spacer drums on the rear. The tyres are 165 and they would be outside the guards without the flares. The smallest flares would cover them though.
M
PostPosted: Fri Apr 21, 2006 9:51 am
If you have the deep dish contessas and regular drums (not cooper S spacered drums) then it should fit under with no flares?
I have LS contessas that are not deep dish and Cooper S brakes at the front with spacered drums at the back and no flares... I believe the difference in the dishes between regular contessas and LS contessas is exactl 1 inch which means logically they fit.
Lillee - 1969 Morris Mini K
Users browsing this forum: No registered users and 72 guests
