It is currently Fri Jul 18, 2025 4:33 pm
 Post subject: 1100 on 850 box
PostPosted: Sat Jun 19, 2004 5:07 pm
I think I have read somewhere that you cant bolt an 1100 engine straight onto an 850 box without modifications.
Is this correct ?
76 1275 Leyland S
PostPosted: Sat Jun 19, 2004 6:10 pm
I'm pretty sure my old motor (1098) was bolted to an 850 box (brass cone synchros - ouch!). I couldn't say for sure but I don't think mods are necessary, I thought that 1275 cranks, and 4 synchro boxes were the ones to be careful with.
Anto.
PostPosted: Sat Jun 19, 2004 6:43 pm
Yeah it fits on- turn it the motor over by hand without any gaskets on the box, if it catches anywhere take it off and grind the marks away. Sometimes on/near the centre web.
Forget a 1275 on that box. I did it once successfully, but it took major surgery which included cutting 4 holes in the front to clear the conrods.. :( Don't go there...
PostPosted: Sat Jun 19, 2004 7:04 pm
Ya could always just put a 998 crank shaft in if it does faul a little. Though by the sounds of it, you wont have any probs.
PostPosted: Sat Jun 19, 2004 7:13 pm
Yeah if it touches it's only a burr or flash in the casting- hardly anything needs to come out for it to miss a 1098.
<edit> ALL my comments in posts above assumed early 850 box- 22A363.
If it's the later box 22G68 there is no problem- this was common to 850, 998, 1100, 997 & 998 Cooper. 8)
Anto, you can put ANY motor on a 4 synchro remote box, or any rodchange box.
