cleaned & linished https://www.ausmini.com/forums/viewtopic.php?f=2&t=89798 |
Author: | TheMiniMan [ Wed Jun 24, 2015 5:42 pm ] |
Post subject: | cleaned & linished |
36 x 1275 cranks over the last couple of days,,, i`m done looks like we`ve saved maybe 25 cranks out of that bundle more to go next week,,, need a break for now ![]() wait till i get onto the small bore cranks, i really dont feel like sifting through about 200 plus little cranks, but it`s got to be done i spose then onto the approx 400 blocks... tell me--> why do i do this>??? i should have been a hair dresser instead,,, ![]() |
Author: | braad [ Wed Jun 24, 2015 6:22 pm ] |
Post subject: | Re: cleaned & linished |
Holy crap. Great effort! |
Author: | drmini in aust [ Wed Jun 24, 2015 6:45 pm ] |
Great stuff Matt. At least they are not going in a skip and off to China like so much has already. ps. please save camshafts too, un-reground ones are getting scarcer now. ![]() |
Author: | TheMiniMan [ Wed Jun 24, 2015 8:23 pm ] |
cams???,,, wellllll... not sure we have many wide lob cams, maybe only a dozen or so & most of are already hotys I `ve been struggling for std wideys for a while now too |
Author: | drmini in aust [ Wed Jun 24, 2015 10:42 pm ] |
Matt, please keep all the good narrow ones, they work too. Even in a 1275 if it's all you can get. Convert em to slot drive with a machined spider adaptor welded in, and Bob's yer aunties husband. ![]() Here's one I prepared earlier (not yet chamfered and TIG welded)- ![]() |
Author: | 9YaTaH [ Thu Jun 25, 2015 9:20 am ] |
Cranky Matt eh...cmon...no crankiness around here mate!! ![]() |
Author: | 16sth [ Thu Jun 25, 2015 2:57 pm ] |
TheMiniMan wrote: 36 x highlights over the last couple of days,,, i`m done looks like we`ve saved maybe 25 split ends out of that bundle more to go next week,,, need a break for now ![]() wait till i get onto the small bob cuts, i really dont feel like sifting through about 200 plus lowlights, but it`s got to be done i spose then onto the approx 400 eyelash tinting... tell me--> why do i do this>??? i should have been a mini engineer instead,,, ![]() Doesn't quite sound the same does it? |
Author: | TheMiniMan [ Thu Jun 25, 2015 3:28 pm ] |
Mick & 16sth,,, you both made my day edit-->(oops, not "dad",,,fat fingers),,, sitting here smiling,,, havn`t had a good hearty smile for a while,,, thank you ![]() & yes i spose that big pile of cranks is pretty-well how ReadSpeed used to be,,, cams & blocks etc too hundreds & hundred of the things i remember once havingyears of simply boring blocks, running into the cold rooms & picking a crank & a cam (already reground/hardened & balanced & linished & just a quick clean, check for size, pick out a new set of bearings out of the bearing cupboard (a whole wall of the damn things) & building mini engines,,, & repeat process for next one,,, over & over & over,,, it was non-stop engine reco system & dad would send 20x cranks away for grind/harden/balance process (done "HIS" way mind you) so we always had plenty of stock, cams too,,, all sorts & grind numbers all in a wall cupboard, all red-rust-prooffed,,, all marked,,, all ready to go. those days are long gone now but the memorys just keep flooding back to those "Good-ol-days ![]() wish dad was here to see what`s happening, he`d be pretty choofed to see the progress but i`m sure he would still be winging & whining that it`s not done the way he wants it , nor would it be done quick enough ![]() anyways,,, back to fitting engines into engine bays i spose, dad would be shitty at me spending time talking to my mates on the net instead of fitting engines ![]() |
Author: | TheMiniMan [ Thu Jun 25, 2015 3:35 pm ] |
& Doc, yes i bough a whole pile of those adaptors from you yonks ago & we`ve been using them & i have a pile of small bore cams that we`re linnishing up now too, but most are hotty grinds too i do have some std ones ![]() but i`m yet to go through all dads stuff yet BBBBIIIIGGGGG Job, ![]() ![]() ![]() every weekend for the next few months i reckon & more than half of it will go into a metal skip bin i reckon ![]() ![]() ![]() |
Author: | 9YaTaH [ Thu Jun 25, 2015 9:50 pm ] |
Keep smiling Matty ![]() ![]() |
