burping smokeing mini
https://www.ausmini.com/forums/viewtopic.php?f=2&t=8982
Author:  joel [ Mon Jul 11, 2005 5:43 pm ]
Post subject:  burping smokeing mini
Started boris up yesterday after not haveing driven him for a week or so,a cloud of white smoke came billoweing out from the exhaust,it kept smokeing for a while and i started to get a bit worried,he hasnt really don this before,its kind of a white grey colour,hr is also makeing burping sounds while idalling,iv been told that this is ptetty normal,it was a cold wet day :idea: to most peaple these things may seem a bit mundain :roll:
Author:  Shard [ Mon Jul 11, 2005 5:58 pm ]
white smoke is water isn't it?
Shard
Author:  willy [ Mon Jul 11, 2005 6:08 pm ]
Indeed.
Would just be condensation in your system, thats steaming up as its getting hot by the exhaust.
Let it run for a good 5 mins before driving... clear up the water.
Author:  mikkis37 [ Mon Jul 11, 2005 6:39 pm ]
Had a similiar problem. Played with engine for a while then gave up and took it up to LINK. Turned out had a hole in the head gasket. Check for oil or crap in the radiaitor or as the others have said run it a bit may clear up good luck!!! :D
Author:  Morris 1100 [ Mon Jul 11, 2005 6:52 pm ]
Cold wet morning = Water vapour out the exhaust pipe. :wink:
Author:  Namibian CAMEL [ Mon Jul 11, 2005 8:41 pm ]
Post subject:  Re: burping smokeing mini
110% correct :wink:
as in yep it always happens
and its normal?
then thats good too :)
Author:  CRU17Y [ Tue Jul 12, 2005 9:42 am ]
I get the same each morning from the overnight dew as i start up the car about 6am.
Author:  J_A_M [ Tue Jul 12, 2005 10:18 am ]
joel wrote:
after not haveing driven him for a week or so,a cloud of white smoke came billoweing out from the exhaust....
I don't want to sound like a pessimist, but if your car sits for a while, and your valve stem seals or valve guides are stuffed, oil can seep down the valve and into the combustion chamber....then burn when the car is started.
I am no expert, so shoot me down in flames if I am incorrect :?
Author:  joel [ Tue Jul 12, 2005 12:55 pm ]
when i first got boris i was told that he had this problem with the valve oil thing with the stem,think it was fixed how would this afect my mini
Author:  scotty [ Tue Jul 12, 2005 1:42 pm ]
Remedy: Don't give your car beer/curry combination the night before...
