Is this front original https://www.ausmini.com/forums/viewtopic.php?f=2&t=89832 |
Page 1 of 2 |
Author: | Morris 1100 [ Sun Jun 28, 2015 9:08 pm ] |
Post subject: | Re: Is this front original |
Those studs are for mounting the fresh air duct for the heater. |
Author: | simon k [ Sun Jun 28, 2015 10:40 pm ] |
yes, that front is original Morris 1100 wrote: Those studs are for mounting the fresh air duct for the heater. so that's what they're for!!!! |
Author: | Bubbacluby [ Sun Jun 28, 2015 11:00 pm ] |
What's the black dot between blinker and headlight? |
Author: | timmy201 [ Mon Jun 29, 2015 7:20 am ] |
I would have thought a late 64 would have had the brake cutouts on the front valence? |
Author: | simon k [ Mon Jun 29, 2015 10:17 am ] |
timmy201 wrote: I would have thought a late 64 would have had the brake cutouts on the front valence? nah, changeover period was '65 |
Author: | Phil 850 [ Mon Jun 29, 2015 6:48 pm ] |
Bubbacluby wrote: What's the black dot between blinker and headlight? It had a set of Domed plastic headlight covers on it. I still have them. The Black Dot is a rubber plug. I'm yet to weld up the holes and touch up the paint. Phil |
Author: | Bubbacluby [ Mon Jun 29, 2015 6:58 pm ] |
Phil 850 wrote: Bubbacluby wrote: What's the black dot between blinker and headlight? It had a set of Domed plastic headlight covers on it. I still have them. The Black Dot is a rubber plug. I'm yet to weld up the holes and touch up the paint. Phil Thanks Phill |
Author: | willy [ Mon Jun 29, 2015 9:25 pm ] |
simon k wrote: timmy201 wrote: I would have thought a late 64 would have had the brake cutouts on the front valence? nah, changeover period was '65 I am seeing some very strange things, as my November 1964 850 has brake cutouts. Body number 59367. I am certain the front panels have never been changed... Whats the go?! |
Author: | Phil 850 [ Mon Jun 29, 2015 9:41 pm ] |
My body number is 55777, so earlier than yours. When I enquirer on here what year/month it was I was informed it was likely November 1964 ?. |
Author: | womble99 [ Mon Jun 29, 2015 11:12 pm ] |
It had contact lenses? ![]() |
Author: | Roundie [ Tue Jun 30, 2015 9:07 am ] |
womble99 wrote: It had contact lenses? ![]() Laser Surgery |
Author: | Goldbrocade_62 [ Tue Jun 30, 2015 12:23 pm ] |
Morris 1100 wrote: Those studs are for mounting the fresh air duct for the heater. I believe they maybe for the horn in the early days |
Author: | Boostedmini [ Tue Jun 30, 2015 1:40 pm ] |
Morris 1100 wrote: Those studs are for mounting the fresh air duct for the heater. my 62 850 had the horn mounted on the studs. as for the front bar mounts, never seen that before, mine has a full length seam with no notches at all as no overrider as std |
