I have finally upgraded the 3 dwell/tachometers that are all stuffed and a 40 year old timing light that only works sometimes and bought myself a proper digital timing light.
http://innova.com/en-US/Product/Detail/5568 .
Here are my current settings.
9deg @ 1000rpm, 12deg @ 1500rpm, 14deg @ 2000rpm, 17deg @ 2500rpm, 19deg @ 3000rpm, 23deg @ 3500rpm , 27deg @ 4000rpm, 30deg @ 4500, Max 32deg @ 5000rpm.
I think my curve is to slow and I may need to back off my springs to speed it up a bit. Maybe a curve similar to this.
10deg @ 1000rpm, 15deg @ 1500rpm, 20deg @ 2000rpm, 24deg @ 2500rpm, 28deg @ 3000rpm, 30deg @ 3500rpm, 32deg max @ 4000rpm
The engine is 1275 auto block 1330cc,Hepolite Pistons. Cooper S crank and rods, lightened flywheel, all balanced. Road/Rally cam, 12G940 head, 1.5 roller tip rockers, LCB extractors, Crane Cams Fireball electronic Ign, 45 DCOE with 36 chokes ( Unknown cam, Unknown compression ratio.)
In the past I have just bent the spring posts willy-nilly but I would like to hear from people that are in the know and have done a few dizzys. Do you use different springs or bend the posts? I am thinking of bending the primary and secondary springs posts a couple of thou to give a little less tension.
Thanks Brad
