It is currently Fri Jul 25, 2025 11:36 pm
 Post subject: 1966 Morris 850
PostPosted: Thu Jul 09, 2015 6:30 pm
I thought they finished in 1965 ?
http://www.gumtree.com.au/s-ad/bakery-h ... 1083501012
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
 Post subject: Re: 1966 Morris 850
PostPosted: Thu Jul 09, 2015 6:43 pm
I have January 66 as the finish date for the Morris 850.
The 850 was replaced by the Mini Minor which commenced in Feb 66.
Is the boot lid correct? 8)
PostPosted: Thu Jul 09, 2015 6:49 pm
Has the correct looking door trims for a minor
PostPosted: Thu Jul 09, 2015 6:53 pm
So some 850's had windup windows :shock: . Would be very scarce , they couldn't have made many of them
1965 Morris 850
1977 Leyland LS
PostPosted: Thu Jul 09, 2015 7:01 pm
My original 64 has the 'short' bootlid.
PostPosted: Thu Jul 09, 2015 7:02 pm
And one 2 screw taillight and one 3 screw..
Is it possible it sat around for a while before being sold in '66? Or it got sold second hand with a new book? Or is the body number right for a '66?
PostPosted: Thu Jul 09, 2015 7:10 pm
The body number is right for a 66. It is the highest number I have seen and it is pretty close to the total production number that I have in a book.
Vic Roads says "no record found" for the number plate...
There are better photos on ebay too
PostPosted: Thu Jul 09, 2015 7:26 pm
This vehicle is build number YMA2S1 60401. The last 850 built was YMA2S1 60688 in January 1966 thus making the advertised car very close to the end of production.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Thu Jul 09, 2015 10:33 pm
Wind up Windows (From the Factory) on a 850??.. I wouldn't have thought the factory would have left the 850 door catch on, as this car has 850 latches.
We have 850 Body shell number...60542... this car had changed to a one piece roof lining, so some changes were showing up in the 850's, we also think it should have an Aust boot, but might have had some that were left over.
To change doors on a car, the check straps usually stay with the door... What check straps were on late 850's with sliding window door??
PostPosted: Thu Jul 09, 2015 10:37 pm
When did sliding windows stop being fitted? I thought it happened when the Morris Mini Minor (850) started.
PostPosted: Fri Jul 10, 2015 6:01 am
It says matching numbers, it didn't say matching panels. :mrgreen:
I don't know what specs the last 850s would have had. The interior is correct (door trims) for a Mini Minor. They started only a couple of weeks this car. Who knows if the last 850s got wind up windows?
The boot lid looks wrong (unless they wanted to get rid of old stock) and one tail light is wrong but that could have happened anytime.
What do you think 850man?
PostPosted: Fri Jul 10, 2015 7:42 pm
The later 850's had a one piece headlining, shorter boot lid and in government fleet pack wind-up windows.
