It is currently Tue Jul 29, 2025 9:31 am
 Post subject: Mini Swaybars
PostPosted: Sat Jul 11, 2015 9:21 am
Hi All,
Just gathering some thoughts from people that run a front swaybar on their mini?
I have a rear bar fitted and I'm looking at tightening up the front, a friend has one I can buy off him but I thought i would ask the question first... The car sees the track on a regular basis...
My car has the following done to the suspension:
HiLo's
AVO Adjustable shocks on the corners
Moulden Cones
Kmac rear bar
Thanks.
"Ex" is an unknown quantity and a S"pert" is a drip under pressure!
 Post subject: Re: Mini Swaybars
PostPosted: Sat Jul 11, 2015 11:28 am
group n racers etc. don't use them...
PostPosted: Sat Jul 11, 2015 11:37 am
to run a front bar you will need a lsd.
PostPosted: Sat Jul 11, 2015 12:04 pm
Already running a Salisbury LSD that is very tightly preloaded. Also I've asked a few "Expert" NB Racers and they come back saying that they have never tried them..... So....
PostPosted: Sat Jul 11, 2015 5:17 pm
The theory behind a stiff-ish rear sway bar on a FWD car like a mini is to increase grip at the front end & reduce understeer.
I know two people who have fitted front sway bars. One is as yet untried on a track only car, the other was road car and the owner was happy with the improvement the front bar gave.
I have a Swift Gti that has uprated Whiteline bars both front & rear. It tended to spin the fronts too easily with the open diff being so stiff.
