Smiths RVI impulse tach with elec ign?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=89915
Author:  SuperCooper [ Thu Jul 09, 2015 7:08 pm ]
Post subject:  Smiths RVI impulse tach with elec ign?
Is anyone using a Smiths RVI impulse tach with elec ign?
Tried last night and it has blown the elec ign module.
Is there a modification needed?
Thanks........
Author:  drmini in aust [ Thu Jul 09, 2015 7:39 pm ]
Post subject:  Re: Smiths RVI impulse tach with elec ign?
I used to run one on Barney's 1293A+ with a Nissan Pulsar electronic dizzy. It worked OK then. However in hot weather it would read inaccurate, probably because it was so old.
Author:  gtogreen1969 [ Thu Jul 09, 2015 8:09 pm ]
There is a mod and a replacement circuit board.
Have a look at this https://www.spiyda.com/magento/index.ph ... board.html
or this http://www.speedycables.com/wiring_tacho_faq.html
Easier to sell the RVI and buy an RVC
Author:  SuperCooper [ Thu Jul 09, 2015 8:14 pm ]
Yep thanks.....ive been looking at that......
Author:  phillb [ Sat Jul 11, 2015 5:30 am ]
I've just had an old 60's smiths tacho updated with a new circuit board to work with electronic ignition.
Humphries Instruments in Wollongong, old school place and did a neat job. Working well so far, nice and smooth. He just needed to check that the old movement for the needle was still working ok.
Author:  Mick [ Sat Jul 11, 2015 10:58 am ]
I've had my electronic ignition running with my RVI for about 6 years now.
The Tacho gauge is passive, and does not emit a signal or alter the 12 volt ignition pulse. It simply watches the current passing through the wire and counts as it goes. I would suggest it was the ignition module or a fault elsewhere.
Usually its the other way around, the stray pulses from the ignition module usually upsets the RVI tacho...
Author:  SuperCooper [ Sat Jul 11, 2015 2:12 pm ]
So do you remember how you wired it? Thanks for the info. Which elec ign modul r u running? Cheers.
Author:  Mick [ Sat Jul 11, 2015 3:22 pm ]
Just one of the UK ones. Simonbbc I used first up, but then I refurbished a 29d dizzy and fitted an accuspark. Simply positive to positive terminal of the coil and the negative from the dizzy makes the loop up to the cabin and back to the negative side of the coil.
Author:  phillb [ Sat Jul 11, 2015 4:05 pm ]
I tried to get the one I had converted to work before it was converted and it wouldn't work. It's marked as RVI and it's one of the type with the adjustable redline needle (approx 1969 vintage)
When I showed it to the Instrument maker he said, no, it won't work with electronic ignition. So I'm not sure why some seem to work and others don't.
Basically the old 60's electronic circuit board with it's oversize resisters etc is replaced with a modern version.
On mine all even all the old terminal connections remain unchanged at the back (POS,NEG and COIL WIRE)
Author:  kiwiinwgtn [ Sat Jul 11, 2015 9:40 pm ]
http://www.dummett.net/ime/website/ime/ ... 2917N.html
http://www.lotuselan.net/forums/elan-mo ... 26919.html
These links are also usefull if you know electronics
