It is currently Thu Jul 24, 2025 12:31 am
PostPosted: Tue Jul 14, 2015 12:01 pm
I am looking to reco my mini k gearbox and was wondering if I should convert to mk2 cooper specs. I am planning on going down the GR 1100 small bore path. I managed to secure a 3.4 final drive. I am after reasonable acceleration and a cruising speed of 110 that doesn't deafen me. A question for ausminiers should I fork out the coin for two gears? What's the benefit over sticking with the current gears?
67 Deluxe under going full resto
PostPosted: Tue Jul 14, 2015 1:25 pm
It will merely be slightly faster top speed in 1, 2 & 3rd, but slightly less acceleration. 4th stays the same.
I've done both my boxes, but these days I'd save yer money. Particularly with a 3.44 diff in yours.
PostPosted: Tue Jul 14, 2015 1:36 pm
Cheers doc. I will spend it on a comp diff pin and save some coin.
PostPosted: Tue Jul 14, 2015 5:00 pm
save your money on that and get a cross pin diff, I wore out a few 'competition' pins then after my diff shattered due to crappy spider gears I got a cross pin. I replaced that with a quaife, but it'll be used again eventually
PostPosted: Tue Jul 14, 2015 5:29 pm
i will not be using for motorsport but will flog it at times. Still worth the $$$
PostPosted: Tue Jul 14, 2015 7:02 pm
If buying a crosspin diff, the Minispares allegedly has a better built reputation than the Minisport (UK) one.
This was the case years ago when I fitted a Minispares diff for someone here. The situation now may be different, I dunno. Do some googling before ya spend $$$... :)
PostPosted: Wed Jul 15, 2015 9:01 pm
I think so... it's all new and unworn pins, spiders, bushes, cage etc.
