It is currently Sat Aug 02, 2025 5:21 pm
 Post subject: 16v
PostPosted: Mon Jul 11, 2005 11:46 pm
Mega tuffness.
Look at that oil return
PostPosted: Tue Jul 12, 2005 3:20 am
There's one of those in Adelaide, William.
A friend of mine owns it. 8)
I have been in it :wink: :P
Revs to 12,000rpm if necessary..... but he has only taken it to 9,000 in my presence...
Yep its a nice piece, thats for sure.
 Post subject: What the..?
PostPosted: Tue Jul 12, 2005 8:39 am
Is that a scavenger pump for dry sump oiling?
Would dry sump work on a Mini? Does it leave enough oil to keep the transmission happy?
Me is confusered :oops:
PostPosted: Tue Jul 12, 2005 8:58 am
yes very tuff in deed, from what i have read and can see the external oil pump is just to get oil to the head as the STD oil pump is not good enough to lubricate the head as well as the motor, and i do not see how that crank pulley for the cams would fit in a mini bit too long.
but i guess you would make it fit hey
100% Pure A Series Turbo
PostPosted: Tue Jul 12, 2005 12:56 pm
Yeah you've seen other engines that can be crammed into minis, right? :lol:
PostPosted: Tue Jul 12, 2005 1:19 pm
Yes, you can dry-sump a Mini. The guy that works at Bernie-Jones Cycles used to have a yellow Clubby with A 10-Litre oil tank in the spare wheel well.
And put me down for one of those KAD engines, too :lol:
PostPosted: Tue Jul 12, 2005 1:22 pm
like so although the belt system looks different on this one
PostPosted: Tue Jul 12, 2005 10:07 pm
i'm guessing that is THE oil pump hanging off the front since the won't be a cam inside the block anymore driving the original one?
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Tue Jul 12, 2005 10:11 pm
Yeah i think thats correct steve
PostPosted: Tue Jul 12, 2005 10:17 pm
Lot of trouble and $$$$$ to get one, and you still only have a 3 bearing A series crank in it.. 12,000rpm? I don't think so..
Power they give is over rated too. :lol:
I'd have a Starlet Turbo and 5 speed in a Mini well before one of these. And I'm not a conversion man! 8)
