Rust Repairs - Leyland Roof Drain https://www.ausmini.com/forums/viewtopic.php?f=2&t=90007 |
Author: | jpodge [ Mon Jul 20, 2015 3:11 pm ] |
Post subject: | Re: Rust Repairs - Leyland Roof Drain |
I recently noticed that mine is the same. You could drill an extra hole there but at the end of the day, if the paint and primer is well and truly protecting the metal in that area, there is nothing to worry about IMO. |
Author: | gtogreen1969 [ Mon Jul 20, 2015 3:27 pm ] |
jpodge wrote: I recently noticed that mine is the same. You could drill an extra hole there but at the end of the day, if the paint and primer is well and truly protecting the metal in that area, there is nothing to worry about IMO. Thanks for the reply. I wouldn't trust my rust repairs - I am a mechanic ![]() I will just watch it and see if it starts to go again. |
Author: | TK [ Mon Jul 20, 2015 5:57 pm ] |
Drill there and you'll probably get a leak in through the door or quarter glass. ![]() |
Author: | drmini in aust [ Mon Jul 20, 2015 6:52 pm ] |
Mini turrets were attached with a continuous resistance roll weld (= a bigass spot welder in continuous mode with knurled, driven copper rollers). It leaves a knurled contact pattern in the bottom of the gutter, usually visible if you remove all the filler & paint. Drill through this pattern at your peril, as TK says you might get a built in shower. One other thing- The inside edge of the gutter was filled with ripstop putty? or something originally. It covered the lap joint inside. Many repaint jobs don't fill this or paint it properly. Then, it rusts. Maybe Sikaflex would do the job these days, but I found it messy to apply. (I'm a fitter, not a painter). ![]() |
Author: | Kennomini [ Mon Jul 20, 2015 8:26 pm ] |
Hint on Sikaflex, (I work with it daily), I'd tape the roof turret up to the edge you want the sealant to go too (2mm or so up from the gutter fold), then apply the sika, wipe excess away with a gloved finger an inch or so at a time and wipe your finger clean each time, use metho on your finger (with a glove) to wipe it back and smooth it off, then peel the tape away and do a final wipe with your finger, metho and rag to smooth the tape edge down. |
Author: | jpodge [ Mon Jul 20, 2015 9:14 pm ] |
Kennomini wrote: Hint on Sikaflex, (I work with it daily), I'd tape the roof turret up to the edge you want the sealant to go too (2mm or so up from the gutter fold), then apply the sika, wipe excess away with a gloved finger an inch or so at a time and wipe your finger clean each time, use metho on your finger (with a glove) to wipe it back and smooth it off, then peel the tape away and do a final wipe with your finger, metho and rag to smooth the tape edge down. Soapy water + finger also does the trick from what I've experienced |
Author: | michaelb [ Mon Jul 20, 2015 9:52 pm ] |
Hey Kevin, some mini gutters appear to be spot welded. I did some repairs on a 67 deluxe recently and that was what I discovered. |
Author: | 69k1100 [ Mon Jul 20, 2015 11:44 pm ] |
Roller resistance welding vs spot welding is a strange one in the mini world. No one is wrong or right, UK or Aussie they all flipped between the two methods at whil. Some outer sills are rollered, others spotted. |
