which carb
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90012
Author:  i got a mini [ Mon Jul 20, 2015 5:42 pm ]
Post subject:  which carb
was talking to a old mini guy he recons he used a std carb 1.5 inch on a super charger I thought they had to be a sealed carb like a hiff 44 is this true or it doesn't matter if they are a suck thru setup
Author:  Morris 1100 [ Mon Jul 20, 2015 6:15 pm ]
Post subject:  Re: which carb
It doesn't matter with a suck through.
Author:  i got a mini [ Mon Jul 20, 2015 6:24 pm ]
Thank u very much
Author:  mini_mad_matt [ Mon Jul 20, 2015 6:30 pm ]
If it's the sc12 kit you will be wanting a HIF carb though because of the internal float. Doesn't need to be a sealed one though.
You may be able to use a HS4/6 but the float bowl hanging off the side will create issues which aren't easily worked around.
Author:  i got a mini [ Mon Jul 20, 2015 6:41 pm ]
Yer it is he sc12 kit the Ben makes still organizing it off him atm so a if I use a std carb I will have issues looks like I am on the look out for a hiff carb any 1 have one :)
