Underseal / bituminous coatings https://www.ausmini.com/forums/viewtopic.php?f=2&t=90055 |
Author: | simonw [ Fri Jul 24, 2015 9:52 pm ] |
Post subject: | Underseal / bituminous coatings |
A question for the brains trust - why? I hate the stuff , specially when restoring but it's so popular Cheap and easy ? Are there any alternatives for an underbody ? Has anybody just undercoated and painted their 'bottoms'? What does it do the dynamat or similar isnt doing inside ? Some here have reported trouble painting over it and I have a mini in my shed full of dried and cracked black stuff and a floor full of rust ... So ... Why do we do it ? Throw your 2c in lads |
Author: | Bubbacluby [ Fri Jul 24, 2015 10:06 pm ] |
Post subject: | Re: Underseal / bituminous coatings |
Stones can hit it and it wont chip off and cause bare metal that will rust like will happen with paint. |
Author: | peterb [ Sat Jul 25, 2015 9:03 am ] |
I used the rubberised coating used on modern cars and the heat moulded (Bitumin?)mats on inside. I only have standard carpets with no underfelt and its all quite civilised inside. I have noticed 1 or 2 'chips' underneath since putting car back on road but nothing dramatic, probably happened when i drove over that Landcruiser the other day. |
Author: | simonw [ Sat Jul 25, 2015 10:26 am ] |
My point too peterb , land cruisers just need to learn their place . But really, I think rust maintenance is probably easier on a painted surface than a bituminous surface . You can see it and deal with it. How many times have we little 'suprises' with the black stuff. Any brand of the moulded mats you used ? |
Author: | peterb [ Sat Jul 25, 2015 4:39 pm ] |
I got the stuff from the painter that did the car. Ask at your local paint/panel shop, they should have them. Just cut to size and cook 'em on with heat gun, looks like it came from factory. Re the Land cruiser, it would have normally cleared but I didn't notice it had a lift kit and roof racks with some mountain bikes on them. |
Author: | KLAS [ Sat Jul 25, 2015 4:44 pm ] |
over here many restored cars just got paint covered with some (nearly) clear wax coat. as you mentioned to better see if it starts to rust again. but most cars used every day get regular underseal if the owner don't want to spend much time under the car. so it's up to you what you prefer |
Author: | simonw [ Sat Jul 25, 2015 10:37 pm ] |
Awesome reply thanks Ian , just what I was looking for ! |
Author: | mickmini [ Sun Jul 26, 2015 11:21 am ] |
I re-did the underside of my 1966 car in about 2009. What i noticed was that where the bituminous coating was intact, there were no signs at all of rust. The original brown rotodip primer was still intact and i did not remove it. On the other hand, along the sides behind the wheels where 40+ years of throwing road debris up had worn away the bituminous coating, there was clearly signs of previous surface rust that had been cleaned up and simply re-primed and painted. There were chips and scratches in that paint that had surface rust. These areas i cleaned up, re-primed and recoated the whole underside with the bituminous coating. My summary conclusion was that the original rotodip primer and coating system is good for more than 40 years of use as long as it is maintained intact. As an aside, there were also areas immediately behind the engine bay, particularly behind the diff, where there was no bituminuous coating left, having been dissolved by oil leaks over many years. The presence of the leaked oil however kept the rust at bay. Oil leaks are not all bad ![]() |
Author: | simonw [ Sun Jul 26, 2015 12:33 pm ] |
Nice rebuild btw ![]() |
Author: | simonw [ Sun Jul 26, 2015 4:24 pm ] |
Good points you raise Mick ..so I think particular attention needs to be paid to bits /area that are inflicted with most Road gunk - wheel wells , firewalls things like these |
