It is currently Fri Jul 25, 2025 11:37 pm
PostPosted: Sun Jul 26, 2015 4:58 pm
Hi, I have a friend that is having issues with his newly assembled motor, the gear box is really tight in first gear, all the other gears are fine.
When you select first it won't turn the motor over going forward, but will turn over when you push backwards
He took it for a test drive and it would only drive in first with full engine power, as soon as you backed of it would lock up
Gear box is a rod change, which has been recently rebuilt
We can't think of anything that could cause this issue so he is looking at engine out to do further investigation
Any suggestions would be appreciated
Mal
PostPosted: Sun Jul 26, 2015 6:06 pm
moved this out of 'wanted'...
could this be caused by a mismatched laygear & gearset?
PostPosted: Sun Jul 26, 2015 7:52 pm
whoops sorry not sure what happened their,
doubt it is lay gear issue, it moves fine in reverse and I am sure he didn't replace any gear sets, but will cheeck
PostPosted: Sun Jul 26, 2015 8:54 pm
what about a missing laygear thrust washer - laygear moves to one end under power and there is a washer there, but when you back off the laygear moves to the other end and grinds itself into the casing
PostPosted: Tue Jul 28, 2015 12:30 am
Mal, I had an 1100cc engine that I rebuilt that did a similar thing once. Was in the ute actually.
I had been driving it around for months fine. Then one day out of the blue started playing up
It would drive normal under acceleration until you backed off and the revs came down below (i cant remember what now as it was so long ago) and the gbox locked up and it skidded to a stop. It did this only 3 times and then was OK again.. wierd or what?!!... I continued on my way home only to get a further 30kms and my low oil pressure light came on so I pulled off the freeway, got out and found a trail of oil left behind.
Got a tow home and inspected. The diff pin had come loose and gouged a slot in the rear diff casing. Pulled it out and found the roll pin that holds the diff pin had been damaged. I think I have photos somewhere actually
I never rebuilt that gbox again, I sold it to a fella who rebuilt the diff and put it back on the engine and never drove it.. you dont by chance have that engine say???
- '74 Clubman Ute project
PostPosted: Tue Jul 28, 2015 12:39 am
Photos of what happened to my gbox. It honestly looks like somehow the diff pin rotated and squashed the roll pin and then was able to roam free out the cage...
PostPosted: Thu Jul 30, 2015 9:18 pm
But that was your diff pin issue causing it to lock up in all gears or just first?
PostPosted: Thu Jul 30, 2015 9:29 pm
I'm not exactly sure anymore
PostPosted: Fri Jul 31, 2015 5:11 pm
reading the first post again, I'm sure I'm right about a missing laygear washer....
it's something that's been left out and something in the 'box is moving into the 'normal' position as long as the engine is pulling the car, when the car is pushing the engine, the 'box is moving to where the missing part is and is locking. It could be selecting 2 gears even....
very curious to find out what it actually is
PostPosted: Sat Aug 22, 2015 9:54 pm
Well , the issue has been resolved, main shaft bearing outer race circlip was not fitted, whole main shaft was moving and would have been jamming against 1st motion bearing, also possible binding helical gears.
Doesn't appear to be to much damage , and will be back on the road before you know it
M
