Stealth Ignition Box. https://www.ausmini.com/forums/viewtopic.php?f=2&t=90212 |
Author: | Convertible Mini [ Mon Aug 10, 2015 7:30 pm ] |
Post subject: | Stealth Ignition Box. |
I sometimes wonder what people do and where they go wrong. I sold someone one of my AEOW DISTRIBUTOR ADVANCE MAPPING BOXES and it was claimed to be NOT working so I just asked to send it back to me for a refund. I rigged it up on my own car and it works perfect. I is so simple to wire up, reprogram and use. I just love the way we can now map the Advance curve and Dwell angle through the rev range in seconds on a computer. Then plug the box back in the car and done. No lengthy time to spend changing springs and modifying weights like we used to do in the past. All you need to do is Lock up the Distributor weights so the Advance will be left to the Box to do. Great gadget. |
Author: | Morris 1100 [ Mon Aug 10, 2015 7:34 pm ] |
Post subject: | Re: Stealth Ignition Box. |
They are a great unit. I love my one. |
Author: | drmini in aust [ Mon Aug 10, 2015 10:42 pm ] |
Me too. ![]() |
Author: | simonw [ Mon Aug 10, 2015 10:58 pm ] |
So there's a second hand unit on the market then ... ![]() |
Author: | boomini [ Tue Aug 11, 2015 2:32 pm ] |
I have a 69d? Unsure of exact model dizzy on my a+. It has the ignition module attached to the side with a 3 wire connection. Only 2 are used. Will this stealth module work on my dizzy? |
Author: | Convertible Mini [ Tue Aug 11, 2015 10:47 pm ] |
The answer is easy to that question. NO. You will need an older type Distributor 59D with the accuspark type Module or one of our Distributors found here. http://www.ebay.com.au/itm/301703003921 ... 1558.l2649 You will also need to lock the weights out so it does not advance mechanically any more. |
Author: | gtogreen1969 [ Tue Aug 11, 2015 10:51 pm ] |
Do you just lockwire the posts? |
Author: | drmini in aust [ Tue Aug 11, 2015 11:01 pm ] |
gtogreen1969 wrote: Do you just lockwire the posts? Yes. The kit includes some 0.6mm SS tie wire. You figure 8 the posts then snip the knot enough to clear the body. There are vids on the Accuspark website. http://accuspark.co.uk/Blackbox.htm |
Author: | mattsmadmini [ Mon Aug 17, 2015 8:22 pm ] |
So... Easiest place to buy in Oz? |
Author: | drmini in aust [ Mon Aug 17, 2015 10:31 pm ] |
I got mine from `Rob Roy' in Victoria but can't find their eBay store now. Or buy Convertible Mini's one, they are the same box. |
Author: | gtogreen1969 [ Mon Aug 17, 2015 11:05 pm ] |
drmini in aust wrote: I got mine from `Rob Roy' in Victoria but can't find their eBay store now. Here it is http://www.ebay.com/itm/Stealth-BlackBo ... d0&vxp=mtr |
