mushroom wrote:
Just had a thought on my brain and was wondering if it was possible. I am looking into air suspension and hydraulics so i can slam my clubby when parked, i have a set hydro displacers and was wondering if anyone could tell me if it was possible to rig up a pump and reservoir so it can let the fluid out and make it hit the deck. then pump it back up so it will still drive like a standard wet suspension mini. Im not interested in them operating individually like some airbag and hydraulic setups, i just want it to sit stupidly low but still be able to drive it.
Could hook the hydro up to a couple of outboard motor trim pumps, 1 for each side. Could maybe use some tricky valving to do it with 1 trim pump.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
