It is currently Tue Jul 22, 2025 2:01 am
PostPosted: Sat Aug 15, 2015 4:18 pm
I am soon changing out my front drum brakes for 8.4 discs. I have spacers on my rear drums (not sure how wide) and I currently have 10 inch wheels but I can see rubbing on one of the shocks. I am not sure if this is currently happening or if it was rubbing and the previous owner put on the spacers. Anyway I will be replacing the shocks and putting on 13x7 minilites :roll: .
Will I need to get the 1 inch stepped drums? and do I have to change the length of the wheel studs to do so? (what size)
PostPosted: Sat Aug 15, 2015 4:39 pm
I THINK I need 58mm wheel studs for 1inch stepped drums.
PostPosted: Sat Aug 15, 2015 5:12 pm
there are 3 lengths, you need the longest ones
you also need 5/8" bore wheel cylinders for the back
no comment on the 13x7 wheels... :roll:
PostPosted: Sat Aug 15, 2015 11:03 pm
I have the different wheel cylinders and I do believe it is the 3rd of 4 lengths. Apparently there is a bigger and thicker drum out there! Yikes. Thanks Simon
PostPosted: Sun Aug 16, 2015 8:22 pm
I have 13x7 on my mini with 8.4" front disks and normal size stepped rear drums and the only thing I think you will need to worry about is how big the flares will need to be. I also believe spacers are illegal? Or have I misinterpreted your details?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Aug 16, 2015 8:28 pm
My rear drums are finned but are the same width as Cooper S stepped drums
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Aug 16, 2015 8:30 pm
I will be trying next weekend, I currently have the 55mm studs, and will be putting the STD 1275GT 1" drums on the back.
Nick
PostPosted: Sun Aug 16, 2015 9:41 pm
Sorry to diverge here but are these the Moulton Smootha Ride cones and hilos.
If so, are you happy with it.
PostPosted: Sun Aug 16, 2015 10:09 pm
Yes it is Smootha ride kit
And yes very happy
It rides similar to hydro car and soaks up the Sydney pot holes very well
I think rear donuts are close to standard but fronts are much bigger in height.
Took a while to settle down to a good ride height but was ok after about 12 months
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Aug 17, 2015 7:42 pm
And yes very happy
Thanks for the info Michael
I had just ordered this kit when I saw the photo of your car and was interested in your experience.
Phil
PostPosted: Tue Aug 18, 2015 8:51 am
I put a smootha ride kit in my Moke about 10 years ago. It was excellent at first, but its not so good now. The cones sagged a lot over the years. It was still worthwhile though.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Aug 18, 2015 9:19 pm
Tell me how you go Hobson, also where did you get yours from?. I am thinking of ordering new cones, gaz lowered shocks and hilos too... only thing stopping me is the coolant leaking from my engine block haha
PostPosted: Wed Aug 26, 2015 3:29 pm
Weather got in the way, hopefully this weekend :roll: - minikingdomonline.com.au
Nick
PostPosted: Sun Sep 27, 2015 3:25 pm
sorry for the 100000000 year response on this, can now confirm you will need longer than 55mm studs, as you only get 2.5 turns on these.
Nick
