It is currently Fri Jul 25, 2025 10:12 am
 Post subject: Overheating on idle
PostPosted: Wed Aug 19, 2015 9:45 pm
My 1098 overheats on idle howeverit will go back down to normal temp once i start driving again. It doesnt take too long to overheat, 5 minutes atthe lights and it starts to creep up. Any suggestions for diagnosis?
 Post subject: Re: Overheating on idle
PostPosted: Wed Aug 19, 2015 10:24 pm
retarded ignition, radiator fan on backwards?
PostPosted: Wed Aug 19, 2015 11:10 pm
You mean in terms of timing?
PostPosted: Wed Aug 19, 2015 11:17 pm
yeah...
PostPosted: Thu Aug 20, 2015 6:23 am
Loose fan belt, partially blocked radiator, corroded water pump. Just suggestions that come to mind. :-)
PostPosted: Sat Aug 22, 2015 2:20 pm
Apparently my fan is on backwards, althought there seen to be some debate about the proper direction. Can anyone clarify this?
PostPosted: Sat Aug 22, 2015 2:21 pm
This is how my fan is currently situated
PostPosted: Sat Aug 22, 2015 4:01 pm
Here ya go. Yours is wrong
viewtopic.php?f=25&t=72688&hilit=fan
PostPosted: Sat Aug 22, 2015 6:23 pm
ohh yeah, called it 8)
fan is rooted too by the looks of the top blade
dunno about newies, but that type of fan actually has "engine side" written on it
