size of 850 door handle retaining screw
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90271
Author:  niffty64 [ Mon Aug 17, 2015 6:51 pm ]
Post subject:  size of 850 door handle retaining screw
just bought keyed alike boot and door handles. There is no thread in the end of door handle shaft.
does anyone know if this should have a screw to expand the slotted end or should i tap it if so what size.
My old ones had a metal screw but a smaller size.
drilled hole in new handle is is 4.7mm .185"
thanks
Author:  wild_willy [ Tue Aug 18, 2015 9:06 am ]
Post subject:  Re: size of 850 door handle retaining screw
On the last set I fitted, I ran a tapped a thread using a 10-32 UNF tap in the existing hole. This gives enough thread to secure the handle to the lock using a pan head 10-32 machine screw and washer. if the handle boss is also screwed to the door using 10-32 screws and appropriate spacers (see Ebay link below)then there won't be any issues with the handle coming loose (not all handle bosses have the threads tapped though).
http://www.ebay.co.uk/itm/Mini-Mk-1-2-D ... 20fdc1bfbe
Author:  niffty64 [ Tue Aug 18, 2015 8:22 pm ]
Thanks wild_willy
i thought it would be UNF.
I drilled out 10mm stainless steel nuts for spacers inside door perfect height.
What a bastard of a Job. you need pixie hands to do up the bolts.
handle shaft sticks through about 3mm making the handle float.
will machine up a spacer washer to fit over square shaft and not foul on the door lock body. i don't really want to cut short the shaft
Author:  bluewhitecoopers1968 [ Tue Aug 18, 2015 8:48 pm ]
So by 10/32 you mean 5/16. ?
Author:  niffty64 [ Tue Aug 18, 2015 9:05 pm ]
#10 UNF is same as 3/16 X 32 TPI. anything under 1/4 UNF has a number.
