It is currently Mon Jul 21, 2025 7:00 am
 Post subject: Front brake pipe length?
PostPosted: Mon Aug 17, 2015 7:29 pm
Hi everyone,
Just wondering if anyone knows the length for the brake pipe that goes from the right hand front brake hose to the left hand side. The one that travels along the front of the subframe. If someone can tell me for sure then i can make the pipe then go out to the car and fit it, instead of removing, going back to make it then going back to the car to fit etc.
This particular one comes straight out from the 2 way banjo fitting for a hydraulic pressure switch and then the usual right angle into the left brake hose.
Matt
PostPosted: Mon Aug 17, 2015 10:21 pm
Matt,
1125mm from flare end to flare end.
Hope this helps.
Dave
PostPosted: Tue Aug 18, 2015 6:16 pm
Thank you very much Dave! Just what i'm after.
