It is currently Mon Jul 14, 2025 3:17 pm
 Post subject: Block sleeving
PostPosted: Sat Aug 22, 2015 12:13 am
Tomboss Breweros
As some of you may already know my minis 1100 had a minor break down after the racing at Hay which included 2 pistons partially melting among other things, this has caused a little damage to the bores.
My question is, can a block with a +0.060 bore be sleeved back to original size, i don't want to bore it bigger to the point of no turning back if i don't have to.
Cheers Tombo.
kimini wrote:
Jimmyinamini wrote:
 Post subject: Re: Block sleeving
PostPosted: Sat Aug 22, 2015 6:07 am
Sure it's possible, but...
Why not just bore it to +.080", you then still have another rebore left, +.100". or, 68mm if you offset bore it.
IMO it's only worth sleeving 1275 blocks, particularly Cooper S ones, due to value.
998-1098 blocks are a dime a dozen, sleeving one would cost way more than the block is worth.
PostPosted: Sat Aug 22, 2015 8:15 am
surely Adrian or someone has a block laying around they don't want...
PostPosted: Sat Aug 22, 2015 10:52 am
I had a Cooper S block dry sleeved by Rhemac in Adelaide, - it was at .60 overbore, & Des returned it to standard bore for a lazy $880.00. I wouldn't have done it if the main caps weren't original & the block wasn't within a few numbers of the one in my Cooper S...
PostPosted: Mon Aug 31, 2015 8:02 pm
Tomboss Breweros
Righto, looks like more bore, anyone recommend who to get a .080 piston and ring set from?
kimini wrote:
PostPosted: Mon Aug 31, 2015 10:01 pm
Graham Russell has +.080" and +.100" flat tops (also has 68mm) with Nippon rings. They are very good.
PostPosted: Tue Sep 01, 2015 6:11 am
Don't buy all the 68's leave a set for me ;)
Simonw
Brisbane QLD
- 1969 Mini K
