Is this a 1.75 Su ?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90296
Author:  simonw [ Thu Aug 20, 2015 7:54 am ]
Post subject:  Is this a 1.75 Su ?
Author:  sitnlo62 [ Thu Aug 20, 2015 8:30 am ]
Post subject:  Re: Is this a 1.75 Su ?
Simon,
That is an 1 1/2" SU
HS4
1 3/4" has a square mounting flange with 4 holes.
Dave
Author:  1071 S [ Thu Aug 20, 2015 8:55 am ]
The "1 3/4 inch" refers to the diameter of the carb inlet.... Find a tape measure??
Cheers, Ian
Author:  timmy201 [ Thu Aug 20, 2015 8:58 am ]
This is mine, you can see the four square bolt holes to the manifold
Author:  drmini in aust [ Thu Aug 20, 2015 9:09 am ]
Cheers, Ian
Actually Ian, no, it refers to the carb outlet size.
AN HS6 has a smaller inlet bore than an HIF44 does, but can be machined out for better flow than stock.
Author:  timmy201 [ Thu Aug 20, 2015 9:13 am ]
Cheers, Ian
Inlet approx 41mm, outlet approx 44mm
Author:  simonw [ Thu Aug 20, 2015 11:04 am ]
sitnlo62 wrote:
Simon,
HS4
Dave
Thanks mate , only had the picture so couldn't measure in person..
anybody have a 1 3/4 they would like to sell ..? Pm me :)
Author:  1071 S [ Thu Aug 20, 2015 7:07 pm ]
Cheers, Ian
Close enough for Government work..... :) Its the principle that counts (ie measure..)
Interesting.. I always thought carbs necked down... Does that mean 6s don't?? The math tells me that 1 3/4" = 44.5 mm
... and the 44 under the bench measures 47(I) and 44 (O)..??? Which I would have known if I'd checked first .. :roll:
Cheers, Ian
