But I'm old school, I distrust turbos or huffers on an A series. I've seen many go BANG over the years.
I tend to agree with you here Doc, BUT, I'm a big fan of the hair drier on the exhaust! The power is not there all the time, only when you want it. Unlike a supercharger, when it starts to produce boost, it is always there.
An engine that has been designed for either a supercharger or a turbo has all the parts, plumbing, emission hoses, ignition curve / map, fueling supply and of course the essential, fuel metering / map! If any of the standard required equipment to run either setup is left off, a recipe for disaster is inevitable. The most common problem I think is ignition curve / map and fueling requirements for the extra boost most people want.
The problem I see when people add these items to a normally aspirated motor, is they get greedy! They want more and more power and don't stick to the original boost they built / designed the motor for. The idea of developing a new engine induction system is to take your time and do things in small steps instead of leaps and bounds. For example, bolting a turbo setup straight onto a N/A motor and taking it for test drive with "Let's see how much boost this makes!" comment as your driving out the driveway! I can see the end result now.....
But to answer simo's original question.....If you do your homework correctly, a N/A small bore with todays engineering skills, will result in a power plant that will rival a lot of standardish 1275's. Bolt on either a turbo or supercharger, with the right cam, and I think you will be more than happy with the end result.
Cheers Shane
