It is currently Tue Jul 22, 2025 7:01 pm
PostPosted: Sat Aug 22, 2015 8:51 am
Morning, the left blinker on the binnacle works as it should but the right will flash once then stop, what could it be thanks?
1993 R32 Nissan Skyline GTR
PostPosted: Sat Aug 22, 2015 11:53 am
It should not be the light itself, but is the indicator can still clicking? Does the external blinkers still blink normally?
At first guess I would look at the indicator can, but something else may be going on depending on the answers to the above.
PostPosted: Sat Aug 22, 2015 6:30 pm
Hey mick thanks for the reply the indicators on the body are functioning
PostPosted: Sat Aug 22, 2015 10:26 pm
Had the same thing a while ago. Didn't get to fix it as the indicators started working by themselves, and are still working! Lucas electrics......
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Aug 23, 2015 6:35 am
I'd be looking at globe holder or printed circuit if its still the club man set up. The printed circuit bits are prone to cracking and corroding. At connections. I don't think it would be the flasher can or switch if the outside lights are working OK.
PostPosted: Sun Aug 23, 2015 6:45 pm
Thanks peterb this car is a round nose, so do you guys reckon the flasher can isn't the culprit?
PostPosted: Sun Aug 23, 2015 6:48 pm
The indicator can runs everything.
I would maybe just change the indicator bulb. It might have a problem with the filament when it gets hot.
PostPosted: Sun Aug 23, 2015 7:06 pm
Ok will do thanks mick
Users browsing this forum: fuzzy-hair-man and 74 guests
