Block sleeving
https://www.ausmini.com/forums/viewtopic.php?f=2&t=90309
Author:  Tombo [ Sat Aug 22, 2015 12:13 am ]
Post subject:  Block sleeving
As some of you may already know my minis 1100 had a minor break down after the racing at Hay which included 2 pistons partially melting among other things, this has caused a little damage to the bores.
My question is, can a block with a +0.060 bore be sleeved back to original size, i don't want to bore it bigger to the point of no turning back if i don't have to.
Cheers Tombo.
Author:  drmini in aust [ Sat Aug 22, 2015 6:07 am ]
Post subject:  Re: Block sleeving
Sure it's possible, but...
Why not just bore it to +.080", you then still have another rebore left, +.100". or, 68mm if you offset bore it.
IMO it's only worth sleeving 1275 blocks, particularly Cooper S ones, due to value.
998-1098 blocks are a dime a dozen, sleeving one would cost way more than the block is worth.
Author:  simon k [ Sat Aug 22, 2015 8:15 am ]
surely Adrian or someone has a block laying around they don't want...
Author:  ianscampbell [ Sat Aug 22, 2015 10:52 am ]
I had a Cooper S block dry sleeved by Rhemac in Adelaide, - it was at .60 overbore, & Des returned it to standard bore for a lazy $880.00. I wouldn't have done it if the main caps weren't original & the block wasn't within a few numbers of the one in my Cooper S...
Author:  Tombo [ Mon Aug 31, 2015 8:02 pm ]
Righto, looks like more bore, anyone recommend who to get a .080 piston and ring set from?
Author:  drmini in aust [ Mon Aug 31, 2015 10:01 pm ]
Graham Russell has +.080" and +.100" flat tops (also has 68mm) with Nippon rings. They are very good.
Author:  simonw [ Tue Sep 01, 2015 6:11 am ]
Don't buy all the 68's leave a set for me ;)
