Indicator on binnacle playing up https://www.ausmini.com/forums/viewtopic.php?f=2&t=90311 |
Author: | davem [ Sat Aug 22, 2015 8:51 am ] |
Post subject: | Indicator on binnacle playing up |
Morning, the left blinker on the binnacle works as it should but the right will flash once then stop, what could it be thanks? |
Author: | Mick [ Sat Aug 22, 2015 11:53 am ] |
Post subject: | Re: Indicator on binnacle playing up |
It should not be the light itself, but is the indicator can still clicking? Does the external blinkers still blink normally? At first guess I would look at the indicator can, but something else may be going on depending on the answers to the above. |
Author: | davem [ Sat Aug 22, 2015 6:30 pm ] |
Hey mick thanks for the reply the indicators on the body are functioning |
Author: | BBY755 [ Sat Aug 22, 2015 10:26 pm ] |
Had the same thing a while ago. Didn't get to fix it as the indicators started working by themselves, and are still working! Lucas electrics...... |
Author: | peterb [ Sun Aug 23, 2015 6:35 am ] |
I'd be looking at globe holder or printed circuit if its still the club man set up. The printed circuit bits are prone to cracking and corroding. At connections. I don't think it would be the flasher can or switch if the outside lights are working OK. |
Author: | davem [ Sun Aug 23, 2015 6:45 pm ] |
peterb wrote: I'd be looking at globe holder or printed circuit if its still the club man set up. The printed circuit bits are prone to cracking and corroding. At connections. I don't think it would be the flasher can or switch if the outside lights are working OK. Thanks peterb this car is a round nose, so do you guys reckon the flasher can isn't the culprit? |
Author: | Mick [ Sun Aug 23, 2015 6:48 pm ] |
The indicator can runs everything. I would maybe just change the indicator bulb. It might have a problem with the filament when it gets hot. |
Author: | davem [ Sun Aug 23, 2015 7:06 pm ] |
Mick wrote: The indicator can runs everything. I would maybe just change the indicator bulb. It might have a problem with the filament when it gets hot. Ok will do thanks mick |
