It is currently Thu Jul 24, 2025 10:56 am
PostPosted: Sat Aug 22, 2015 8:01 pm
Hi all,
After discovering that the tyre fitter had over tightened my Contessa wheel nuts, and has stripped some, I have ordered a full set (16) from Mini Kingdom.
What is the correct torque setting and can you put anti-seize on the threads, or should they be dry?
Jim :)
PostPosted: Sat Aug 22, 2015 8:27 pm
I use 40 ft/lb and the threads are very lightly oiled.
Curly
PostPosted: Sat Aug 22, 2015 10:38 pm
How are the studs? Might be worthwhile replacing them as well :idea:
PostPosted: Sat Aug 22, 2015 10:45 pm
The studs are fine I've checked them closely. The nuts wore the brunt of the brute force.
PostPosted: Sun Aug 23, 2015 7:05 am
I never use a rattle gun I always tighten by hand then use a torque wrench to tighten up
I got a call the other week to take off a tyre off a Toyota I needed a 4 foot pipe on the wheel brace to get the nuts off and I bent a brace that was 10 mm rod like a banana
Mate wasn't happy as he got new tyres put on 2 days before the flat I haven't seen him to ask if he went to the tyre shop about the very tight nuts
