Contessa Wheel Nut Torque Value https://www.ausmini.com/forums/viewtopic.php?f=2&t=90318 |
Author: | jb007 [ Sat Aug 22, 2015 8:01 pm ] |
Post subject: | Contessa Wheel Nut Torque Value |
Hi all, After discovering that the tyre fitter had over tightened my Contessa wheel nuts, and has stripped some, I have ordered a full set (16) from Mini Kingdom. What is the correct torque setting and can you put anti-seize on the threads, or should they be dry? Cheers, Jim ![]() |
Author: | Curly [ Sat Aug 22, 2015 8:27 pm ] |
Post subject: | Re: Contessa Wheel Nut Torque Value |
I use 40 ft/lb and the threads are very lightly oiled. |
Author: | 9YaTaH [ Sat Aug 22, 2015 10:38 pm ] |
How are the studs? Might be worthwhile replacing them as well ![]() |
Author: | jb007 [ Sat Aug 22, 2015 10:45 pm ] |
The studs are fine I've checked them closely. The nuts wore the brunt of the brute force. |
Author: | drjbeam [ Sun Aug 23, 2015 7:05 am ] |
I never use a rattle gun I always tighten by hand then use a torque wrench to tighten up I got a call the other week to take off a tyre off a Toyota I needed a 4 foot pipe on the wheel brace to get the nuts off and I bent a brace that was 10 mm rod like a banana Mate wasn't happy as he got new tyres put on 2 days before the flat I haven't seen him to ask if he went to the tyre shop about the very tight nuts |
