It is currently Mon Aug 18, 2025 3:18 am
PostPosted: Tue Aug 25, 2015 5:09 pm
I Recently bought a nice new shiny Alloy Rocker cover but it doesn't fit my engine it is not able to sit flush against the gasket/head because of two bolts either end of the head... the original factory cover has two cut outs either side of it to allow for a flush fit... have I bought the wrong rocker cover? the description from the store reads " Fits all standard A-series engines as fitted to Mini and Moke" the engine number prefix is 9fxey.
I forgot to mention I also bought two of the T bars which secure the cover in place the right side screws down nicely but the left side doesn't??
Jenk.
PostPosted: Tue Aug 25, 2015 5:14 pm
Grind or file it to fit around the bolts
Mark
PostPosted: Tue Aug 25, 2015 5:19 pm
With the T bars, is the one that doesn't screw down nicely, does it screw on quite a long way but doesn't press against the rocker cover? If so you need a thick washer as the stud is bottoming out inside the T bar.
If it just plain doesn't screw on there may be an issue with the threads on the stud or the T bar
PostPosted: Tue Aug 25, 2015 5:25 pm
Mark
Thanks Mark, I did consider that for a brief silly moment but its made to for a mini it should already fit without having to modify it.
Jenk.
PostPosted: Tue Aug 25, 2015 5:27 pm
yes it screws down nicely but just bottoms out before any force is applied to the rocker cover its not threaded or anything! you might be right bout the thick washer... thanks.
Jenk.
PostPosted: Tue Aug 25, 2015 5:34 pm
These are built for 9 stud heads (ie your run of the mill Minis).
You have a Cooper S head - with 11 studs - and will need to relieve the cover to suit.
Use your standard cover as a template.
Easy!!!!!
PostPosted: Tue Aug 25, 2015 5:48 pm
Easy!!!!!
Thanks willy.
Jenk.
PostPosted: Tue Aug 25, 2015 7:38 pm
Yep that's what I had to do to mine also
PostPosted: Tue Aug 25, 2015 8:35 pm
Easy!!!!!
Thanks willy.
No worries, happy to help.
PostPosted: Thu Aug 27, 2015 6:52 am
On my cover, before fitting the T bar... Rubber seal, cup washer, 3mm metal spacer then T bar, also make sure the rubber seal is in good condition, preferably fit new ones. Here's a pic that might help too.
PostPosted: Thu Aug 27, 2015 7:19 am
Thanks, on looking at it again there are no rubbers, only the cup washer, Ive ordered the rubbers couldn't find the spacer washers or spring washers to buy on their own only as a set if I order the whole T bar kit but already have the T bars, Ill work something out.... cheers.
Jenk.
PostPosted: Thu Aug 27, 2015 7:41 am
Thanks, on looking at it again there are no rubbers, only the cup washer, Ive ordered the rubbers couldn't find the spacer washers or spring washers to buy on their own only as a set if I order the whole T bar kit.
This is what your after, easy enough to improvise.
http://www.minispares.com/product/Class ... |Back%20to
PostPosted: Thu Aug 27, 2015 7:44 am
I found the rubber rocker cover grommets you buy now are allergic to oil! Once upon a time they were neoprene or similar.
Last time I had mine off I flung them, and made some 5mm thick polyurethane washers instead.
PostPosted: Thu Aug 27, 2015 8:15 am
You can get neoprene grommets from Minispares. Mine have been on for years and are still good. Cheers.
PostPosted: Thu Aug 27, 2015 8:00 pm
Thanks Guys.
Jenk.
Users browsing this forum: No registered users and 197 guests
