It is currently Sat Jul 19, 2025 9:43 am
PostPosted: Fri Aug 28, 2015 7:15 pm
https://m.youtube.com/watch?v=R1DtY2VwSyY
Looks to work
PostPosted: Fri Aug 28, 2015 9:04 pm
I need a container big enough for my whole car!
Has anyone tried using CLR without the vibration? I would imagine if you shook it up every now and then you would get the same result in less time than it would take you to buy the Velcro and make the adaptor... But it's not as fun
PostPosted: Fri Aug 28, 2015 10:52 pm
I've only tried clr on a kettle is good stuff cleaned the inside like new
There's also a product called simple green that's not bad stuff either i noticed masters sold it the other day I got some years ago off tvsn
PostPosted: Sat Aug 29, 2015 5:27 pm
Supercheap are now selling ultrasonic cleaners. http://search.supercheapauto.com.au/sup ... ic-Cleaner
Might have a go at making one.
Member VMCI #19
PostPosted: Sat Aug 29, 2015 6:06 pm
cool. my sander already has velcro on it for the sandpaper . . .
PostPosted: Sun Aug 30, 2015 6:33 pm
That was my first thought , i've been using white vinegar to clean up some metal parts
off my van and it works well i've found , might give the CLR a try.
